Active X container Mouse Enter and Mouse Leave Events
I am not able to get these events to work properly. When I enter the Active X container both events fire off continuously whenever the mouse moves within the container. Does anyone have a solution for this and/or has seen this behavior before?
Randall Pursley
(2,888 Views)
It seems that when the control is empty it works fine, but if it has something in it, it starts this. Here's a quick example I made (7.1).
___________________
Try to take over the world!
(2,884 Views)
That is what I found as well. I worked around it by putting a picture control behind the container and made it the same size so the events generated by the picture control are equivalent to the ones that would be generated by the active X control.
Randall Pursley
(2,881 Views)
