ActiveX Excel - how to choose the whole column
I can access individual cells in Excel using the Range object but I could not figure out how to select the whole column. Here is essentially what I'm trying to do if I were to do it with a mouse in Excel.
"Select Column A -> right click to choose "Format Cells..." -> Under the Alignmnet tab, click the "shrink to fit" checkbox."
Thank you very much.
Jae-Ho
(3,460 Views)
This should work for you.
For more information and some sample VI's and tool kits, you can go to the excel board
Message Edited by Jhoskins on 01-31-2007 07:36 PM
Joe.
"NOTHING IS EVER EASY"
(3,457 Views)
Hi, I'm sorry for the trouble but could you please save it as LabVIEW 7.1? Also thank you for the link to the excel board. Thanks
Jae-Ho
(3,454 Views)
Sorry I cannot go back that far. Here is a screen shot.
Message Edited by Jhoskins on 01-31-2007 07:41 PM
Joe.
(3,452 Views)
I just tried it following the diagram but was confused with what the "Column" string control contained to select the whole colmun, say column "A". I can do it to individual cells if I connect "A1"
Thank you.
Jae-Ho
(3,447 Views)
In the column string control type in a:a to select the whole column A.
Joe.
(3,444 Views)
