ActiveX / Nanoscan - Invoke Nodes don't work
I'm trying to get the Nanoscan (Photon Inc.) to work via ActiveX. There is a sample vi (from LabView 6) included but that doesn't work. So I tried to write an own short vi with only 2 commands. But that doesn't work either.
Error -2147352561 is returned.
Please find the test.vi (LV2009) I used attached. Property Nodes work, Invoke Nodes don't.
Any help in this matter is greatly appreciated!
Steffen
(4,234 Views)
that's a known problem.
Have you tried creating new property nodes and reassigning the properties to see if this fixes the issue?
Regards
Rüdiger
(4,198 Views)
Hi Rüdiger,
Thank you for your help.
Yes I already tried that. I started with an empty vi and from there I added the components from the menu. But it didn't fix the problem. All Invoke Nodes don't work.
Do you have some more ideas?
Steffen
(4,193 Views)
Hello Steffen,
could you contact the Nanoscan support in order to ask for a new version of the type library?
Regards
Rüdiger
(4,170 Views)
Hello Rüdiger,
I already contacted them. But they also have no clue why it isn't working. They know that it works with older Labview versions.
Steffen
(4,145 Views)
Hello All,
The sample works with later versions of labview after all the invoke nodes have been deleted and re-added.
The error code -2147352561 is 8002000F in hex, which translates to an error of "parameter not optional," however in steffens .vi, he is trying to call a method with 0 parameters. The error makes no sense in this context, since the method has no parameters at all. This is the issue that we (at photon) don't understand: why are you getting a "parameter not optional" error on an invoke with zero parameters? The function in question, NsAsAquireSync1Rev(), has been tested and works without any problems in other activeX clients.
I wonder if anyone at NI knows why an invoke of a zero paremeter function, would result in a "parameter not optional" error.
(4,008 Views)
