Bug: Nesting libraries breaks inheritance
[Originally posted on LAVA]
Environment is LV9.0.1 on Windows 7.
I've attached a small project that can be used to repro the bug.  It contains 2 libraries, MainLibrary and SubLibrary.  The libraries are not nested.  SubLibrary contains two classes, Parent and Child.  Child inherits from Parent.
Repro:
1. Open the Error List windows.  Note there are no errors.
2. Drag SubLibrary into MainLibrary so the entire library is nested.  (i.e. MainLibrary:SubLibrary:Parent.lvclass)
Result - The following error occurs in MainLibrary:SubLibrary:Child,
"The parent of this Labview class is private and is not accessible from this class."
Expected Result - No errors.
Work around 1 - Setting the access scope of either Parent.lvclass or SubLibrary.lvlib causes LV to reanalyze the permissions and remove the error.
Work around 2 - When the libraries are not nested, first move all the classes from SubLibrary to MainLibrary.  Then nest SubLibrary in MainLibrary.  Finally, move the classes from MainLibrary to SubLibrary.
(4,898 Views)
Daklu,
I have taken a look at the example project you created and verified the behavior you were seeing. This was reported to R&D (CAR #236169) for further investigation. I also infomed R&D about the workarounds you provided for this issue. Thank you for the feedback!
Stephanie A.
Americas Marketing Manager
(4,865 Views)
This CAR is fixed in LabVIEW 2010.
(4,793 Views)
