04-29-2010 06:09 AM - edited 04-29-2010 06:09 AM
HI srikrishnaNF
I am using MS spreadsheet 10.0 and I inserted it as a control rather than as a document. Is it becasue of this?
I have not insert any other file, the excel in this programme is simiply as indicator with same function as table.  The reason I am using Excel in ActiveX container is becasue I have never used it before.
 srikrishnaNF
			srikrishnaNF
			04-29-2010 06:27 AM
 muks
			muks
			04-29-2010 06:49 AM - edited 04-29-2010 06:50 AM
srikrishnaNF wrote:hi,
The reason must be ,the system in you are trying to run the program may not have office xp installed..
Thanks and regards,
srikrishnaNF
You mean ms office? but then how did he get that ms spreadsheet 10?
 srikrishnaNF
			srikrishnaNF
			04-29-2010 07:09 AM
hi fluencyu,
If office xp is already installed ,then another option is you need to install the webcomponents of office...You can download and install from
By installing this component only,you will get the activex object as microsoft office spreadsheet 10.0.
Thanks and regards,
srikrishnaNF
04-30-2010 04:25 AM
Hi all
many thanks for your help
I am working on this today and I will let you know whether it could be sorted
thanks,
F.
05-04-2010 09:47 AM
Hi
I have been working on this problem but still did not have it solved yet.
I built application with 'enable activex server' checked and installed office webcomponents.
I also tried to regsvr32.exe execel.exe, but it says it is not .dll or .ocx file and it can not be registered.
King Regards,
Yu
 srikrishnaNF
			srikrishnaNF
			05-04-2010 12:15 PM
05-05-2010 03:57 AM
Hi srikrishnaNF,
Yes I did.  But I still got nothing.
Fluencyu
 srikrishnaNF
			srikrishnaNF
			05-05-2010 04:35 AM
05-05-2010 04:47 AM
hi
I am usingoffice 2003 on the computers both for progamming and applying executable file
os for both computer are xp
I will upload an example (VI and executable file ) later
thanks,
Fluencyu
