The "quick fix" only fixes the problem when you run a VI from LabView. If
you use the LabView Application Builder to build an EXE and redistribution
package you will still have the same problem. The redistributable LabView
Run Time Engine contains the old ole_lv5container DLL. I don't see a way to
change the version of the DLL that gets redistributed (by using the LabView
Application Builder and LabView Run Time Engine) based on the "quick fix".
And
speaking of versions, the new "ole_lv5container.dll" file has the same
version as the one that originally came with LabView 5.1 (1.0.0.1). This
makes it difficult to replace the old DLL even with a custom setup program
because
the versions are the same.
Steven Harrison wrote in message
new
s:384ef671@newsgroups.ni.com...
> Mark,
> You are correct; the LV 5.1 container does leave some stray files, and
that
> is indeed a bug. Here is the URL of a KnowledgeBase article (1M9AOOFP)
that
> describes the problem:
http://digital.natinst.com/public.nsf/web/lastweek/862567530005F09E8625678C0
05C3E98?OpenDocument
> Attached to that article is a quick fix for the problem. The problem will
> also be resolved in future versions.
> Regards,
> Steven Harrison
> National Instruments
