Showing results forĀ
Search instead forĀ
Did you mean:Ā
ActiveX error 0x80070002
i build vi server on app(.exe), base active x Labview._Application class.
i call "GetViReference" method and call the vi(from llb).
its work good on develop computer, but on computer that only run-time installed(no labview develop environment) i receive from the "GetViReference" method error: "The system cannot find the file specified." code: -2147024894.
thanks
(4,454 Views)
(4,441 Views)
Thanks but i have no constant path in my code.. so i dont see a solution in that link
(4,436 Views)
Did you included the llb in the build specifications?
Ben64
(4,395 Views)
Thanks for the comment,
No, because the exe need to be a generic vi/llb launcher.
(4,382 Views)
