07-08-2003 04:02 AM
07-09-2003
10:11 AM
- last edited on
05-17-2026
02:07 PM
by
Content Cleaner
This is something that might help you out. This KnowledgeBase [link removed; article no longer available] on NI's website discusses a problem with the LabVIEW 3D Graphs inside subpanels. They are ActiveX objects also so yours could be a similar issue. It talks about making the containers invisible and visible and solved the solution for that. It will hopefully work for you too.
07-10-2003 03:14 AM
07-16-2003 02:52 AM
08-15-2005 06:49 AM
08-15-2005 06:56 AM
08-15-2005 01:52 PM
Hi tst,
I registered at LAVA forums about one week ago, but couldn't download that file. Thank you for that example from LAVA.
unfortunately I think that it's not the solution of my prblem.
Is this issue a LV bug? please see the example I've uploaded and tell me if you see any mistake. If you think explaining the problem in a more detailed way may bring you some ideas, please let me know.
I've designed a multi-view GUI using a subpanel to give the user, the opportunity to navigate among FPs of continuously running VIs. In most of these VIs are activeX objects e.g. NI HyperTrend of DSC module. The above example is a simple form of the functionality I'm looking for and also demonstrates the problem I'm facing.
08-16-2005 01:37 AM
NI should really do something to improve subpanel performance or at least publish more detailed documents on its structure. Here is a new point! take a look at this version of "example".
When you have activeX objects on a panel loaded in a subpanel and you make that subpanel invisible, the subpanel frame and the front panel inside will be invisible, but the axtiveX object is still there! see by yourself if you're not agreed.
I think the final result of this discussion will be a link in "August 2005 Monthly Bugs" thread and nothing else. then I should play with visibility properties of these objects. boring job!
Any other Idea?
08-16-2005 02:24 AM
08-16-2005 02:57 AM
I've seen cases where ActiveX containers become invisible when saving to an older version or when opening the VI with the container in a different computer. I haven't really worked with subpanels, so I don't know about that.
I can't open your 7.1 VIs here (only 7.0).
And you're not the only one far from NIWeek... ![]()
