Actor Framework Message Maker Dialog Box missing
In Labview 2015 should be a Actor Framework Message Maker Dialog Box.
I create a new project from the Actor Framwork Template, but can not find in the Tools menu Tools»Actor Framework Message Maker.
In the context menu of Task.vi in Alpha.lvclass I have Actor Framework»Create Message.
So I can create a new message class.
But why is Tools»Actor Framework Message Maker missing?
Message 1 of 9
(8,766 Views)
Interesting, can you post this in the AF Comunity Directly? It'll get much more focused attention there Smiley Happy
https://forums.ni.com/t5/Actor-Framework/ct-p/7001
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 2 of 9
(8,744 Views)
Accepted by Peter_S
The Message Maker was deprecated. The 'Actor Framework' right-click menus in the project window in LabVIEW 2015 and later should provide all the functionality previously provided by the message maker.
I thought we removed the help topic, I'm not sure why it's still showing up in the LabVIEW 2015 online help. I filed CAR 565761 to get the documentation updated.
Message 3 of 9
(8,731 Views)
Thanks.I have also Labview 2014 installed with the menu Tools»Actor Framework Message Maker, but not with 'Actor Framework' right-click menus.
Message 4 of 9
(8,722 Views)
Right, to clarify:
  • 2014 and previous has the Message Maker in the tools menu
  • 2015 has the Project Provider with the right click menus
Message 5 of 9
(8,708 Views)
To be precise: Right click the actor class of your interest in the project, go to "Actor Framework" and "Create Abstract Message for Caller" (LabVIEW 2016)
Message 6 of 9
(8,153 Views)
So,  That gives me an Abstract Message.  How do I create an ordinary non-abstract message?
Message 7 of 9
(7,410 Views)
There is also a 'Create Messages for Actor' right-click menu option that creates standard messages.
Message 8 of 9
(7,404 Views)
  It appears that, first, you have to create a method for the message to link to. Only then will the Create message option be added alongside the Create Abstract message option.
  Ian
Message 9 of 9
(7,396 Views)
