Actual Version of NI-DAQmx for windows 8.1 Enterprise
I wanted to use MAX tool with Labview 2016. But when i started the MAX and wanted to right click on "Devices & Interfaces" for creating new item. Nothing Happened by right click. Then i read on a forum of NI that NI VISA drivers needs to be installed . Then i installed that VISA driver and luckily i was then able to right click on "Devices & interfaces" but  only three icons are listed as shown by me in attached jpeg.
But here in  "Create NEW" window i wish to have a list that contain more icons as in this youtube video See the list in "create new" window after right cliking devices & interfaces
(3,622 Views)
i also tried installing Ni-DAQmx driver from  top most of list of link for downloading ni drivers but when it completed downloading the 1.5 GB setup and i wished to run that application but my windows 8.1 Enterprise replied that this app can't run on your operating system.
(3,619 Views)
MAX, the Measurement and Automation eXplorer, shows you the devices that LabVIEW can use, which corresponds closely with the devices whose NI Drivers you have installed.  So if you install NI VISA, you will see serial and parallel port devices.
If you want to use other devices, you need to install their drivers.  And as you want to see/use them in LabVIEW, you need to install the NI (LabVIEW) drivers for these devices.
(3,597 Views)
Thanks dear BOB.
Will you please let me know where i can find such drivers that are compatible with windows 8.1 Enterprise. Bcz on NI website i found drivers for other versions of windows but couldn't fine driver for windows 8.1 Enterprise
(3,576 Views)
Accepted by ibn-e-safi
Hello ibn-e-safi,
Here is the list of NI software compatible for windows 8,
you can check it out here:
http://www.ni.com/white-paper/14281/en/
-Andrea Gamboa
Applications Enginner
(3,556 Views)
Can you look through the list of system requirements for the version of DAQmx you downloaded, and check that your system meets them all?
Edit: here they are:
System Requirements
System Use RAM Processor
Development/Deployment 1 GB (32-bit), 2 GB (64-bit) 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
Supported Operating Systems
The following operating systems are supported in NI-DAQmx 16.1:
  • Windows 10 (32-bit and 64-bit)
  • Windows 8.11 (32-bit and 64-bit)
  • Windows 7 SP12 (32-bit and 64-bit)
  • Windows Embedded Standard 72, SP1 (32-bit and 64-bit)
  • Windows Server 2012 R21 (64-bit)
  • Windows Server 2008 R21, SP1 (64-bit, not supported on Server Core Role)
1 NI software installs VC2015 Runtime and .NET 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
To find and download an earlier version of NI-DAQmx that supports other operating systems, refer to ni.com/downloads.
Application Software Support
The following table lists the application software versions supported by NI-DAQmx. If you are not using application software, refer to Microsoft Visual Studio Support.
Application Software Versions Supported by NI-DAQmx and the DAQ Assistant
LabVIEW 2013, 2014, 2015, and 2016
LabVIEW Real-Time Module 2013, 2014, 2015, and 2016
LabWindows/CVI 9.0, 2009, 2010, 2012, 2013, and 2015
LabWindows/CVI Real-Time Module 9.0, 2009, 2010, 2012, 2013, and 2015
Measurement Studio 2010, 2012, 2013, and 2015
SignalExpress 2012, 2013, 2014, and 2015
(3,551 Views)
