Adaptive signal processing
I have simulated ECG waveform,I need to delay this by 16 samples and give it to the "AFT filter signal and update coefficients.vi" as d(n) and original ECG as x(n).But it says length of these signals are different and throws an error.For the delaying part, I have tried Z transform delay and also by adding delay to the t0 of the waveform.But none of them worked.I am still a beginner in Labview.Please do help me.
(3,350 Views)
How did you implement the delay? You can easily check the lengths by using Get Waveform Componenets and checking the Size of the Y arrays.
Please post your VI so that we can help.
Lynn
(3,321 Views)
Please go through the following discussion thread to understand the insertion of phase delay between two waveforms using FFT function.
http://forums.ni.com/t5/LabVIEW/HELP-how-do-I-correctly-apply-a-phase-shift-to-a-waveform/m-p/51942?...
Ankur
(3,292 Views)
guys this is my project .
is my adaptive filter circuit true ?
please help me
(3,251 Views)
