coverting pid in to a c code
hi all ,
i have implemented a PI controller for my air heater controller using labview PID.
The PID blocks input range is as follows
min  - 48300
max - 65000
With the Kc = 10 , Ki=8000 , the output is perfect . But now my question is how to implement the same using a c code.
Can some one suggest me whether the below program is right or not ?
loop {
error = sp_temp - actual_temp;
integral = integral + error*dt;
output = Kp*error + Ki*integral    (where Kc = kp =10 , Ki = Kp/Ti = 10/8000 = 1.25e-3)
how can i implement the min and max values in c implementation .
(2,559 Views)
It might be a bit long winded, but if you double click on the PID.vi and check out it's block diagram you'll see precisely how LabVIEW goes about performing PID Control.
From what I can see, the VI just uses an In Range and Coerce block to force values to a set window. I guess the equivalent in C would be an If Statement controlled by the maximum and minimum input parameters, and the current value to output.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(2,521 Views)
Hi john,
unfortunately there is no PID toolkit for LabWindows/CVI. You can either try to to search for a mathematic code,which representates your pid behaviour in c code or create a dll in LabVIEW. You told me that you have a working VI with LabVIEW PID, so if you have the application builder you can build a .dll out of your labview code and include this .dll in labwindows/CVI.
Joaquin
(2,483 Views)
