Adaptive terminal connection
I'd like to use a SubVI with two different inputs type: 2D or 1D arrays. Is it possible to create a terminal connection of a SubVI that will allow to connect two different types of wire?
(3,764 Views)
Accepted by topic author maxim.neradovskiy
Hi Maxim,
sure you can!
Look up the LabVIEW help for "polymorphic VIs"!
(3,761 Views)
Thanks a lot. I've spent a lot of time to choose the right adjective. It was "polymorphic".
(3,752 Views)
