Add Signal Names (Headers) to Write To Measurement File vi
Hello, I'm a beginner to LabVIEW and need help with writing headers to my file created through the Write to Measurement File vi. I have one DAQ Assistant with eight different outputs, each output having its unique identifier. I'm reading the outputs to the Write to Measurement File vi but when I view the xlsx file, the headers show up as 'untitled 1", "untitled 2", etc. How can I display the correct header name to the final file?
(1,173 Views)
Please attach your VI so we can more clearly see what you are doing.  Many of us don't have the latest LabVIEW version, so it is best if you "Save for Previous Version" and specify LabVIEW 2019 or 2021.
(1,147 Views)
Hi Bob, I've attached a similar vi to what I'm working with. What I'm trying to do is get headers for the various signals and numeric controls to the saved xlsx file. I've tried with "Set Dynamic Data Attributes" but it's very clunky given how many signals I need headers for. Any inputs would be appreciated!
(1,105 Views)
Accepted by asb328
Hi asb,
when you want to use ExpressVIs and their DDT datatype wires then you need to use even more ExpressVIs (SetDynamicdataAttributes) to apply labels to your signals!
To make it a little less clunky you should think about using a loop to label one signal after the other: you only need one instance of SetDynamicDataAttribute:
(1,101 Views)
Thank you so much! This works and makes it a lot neater.
(1,054 Views)
