Add VI's to the Quick Drop List
Hello everybody,
I was wondering if it is possible to add VIs to the Quick Drop. I often use a couple of VI's in a project and I always have to add them manually.
Is it possible to do something like creating a Folder in Program Files (x86)\National Instruments\LabVIEW 2019\vi.lib\ ?
I did that but it didn't work. I also created a Library, but it doesn't work either.
Is there any way to actually do this? Or anything similar?
Thank you in advance.
Best Regards.
My Channel: https://www.youtube.com/@LV_Lab
(4,177 Views)
Accepted by topic author AldhairGarza
I believe if you put them on the palettes (for example, by using VIPM or manually building a .mnu file) then they will appear in quick drop.
GCentral
(4,161 Views)
You are the best! It worked like a charm. I build a Package and installed it.
Thank you very much.
(4,148 Views)
