Controlling a Keysight (Agilent) N8921A DC Power Supply Using IVI Driver
All,
I am working with an Keysight/Agilent N8921A DC power supply.
The IVI subVIs that are available to me are "Configure Voltage Level.vi" and "Configure Current Limit.vi." When I set values for voltage level and current limit, the power supply sets the proper voltage level, but sets the current level to zero, as though it was expecting a command for the current level, not the current limit. I have tried all the available subVIs I can find in the "DC Pwr Supply" folder, but I cannot seem to find one that sets the current level.
Has anyone written code for this power supply using IVI drivers? If so, could you post a snippet?
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
Message 1 of 9
(5,036 Views)
Have you tried the SCPI command manual for any current level. Maybe you can write it using VISA write with the command. you cannot expect all function in drivers.
Thanks & Regards,
Bharath Kumar
GCentral
Message 2 of 9
(4,856 Views)
Message 3 of 9
(4,847 Views)
The plug and play driver works perfectly.  We are hoping to transition to IVI drivers to make expansion and reuse simpler. But if they lack basic functions like setting current level, we may have to rethink that strategy.
Forbes Black
Message 4 of 9
(4,826 Views)
Forget the IVI drivers, I have never had good luck using them
You are probably going to have to make your own drivers for that Agilent power supply like I did using the SCPI commands in the manual
=== Engineer Ambiguously ===
Message 5 of 9
(4,798 Views)
Could someone please post a link to the SCPI Command Manual?
I found this
Forbes Black
Message 6 of 9
(4,784 Views)
Doh!
Message 7 of 9
(4,775 Views)
I usually start with the manufacturers website when I am looking for documentation or drivers?
Message 8 of 9
(4,772 Views)
Yes, I downloaded the Keysight manual. I just wasn't sure if that was the exact one that people were referencing.
Forbes Black
Message 9 of 9
(4,766 Views)
