Add a immage to report headder
Hi ALL
I need to add a immage (company logo) to the headder of a report that i am creating useing Labview 8.5 on Windows XP.
How do I do this?
(2,759 Views)
Hi Percy,
You can do this by using "Append Image to Report.vi" from the report generation toolkit.
(2,735 Views)
Thank you I tried this but it looks like the immage is added to the boddy of the report and not to the header I am using a starndard report. and need to add the immage to the top left corner of the page header of the report.
(2,728 Views)
Ah yes, you would need to make a small change to the existing subVI.  Open up Append Image to Report.vi, and change the Report property type from "Report Data" to "Center Header Data".  Now, save this VI in a different location (DO NOT REPLACE the original file.)  This VI should give you the functionality you'd like.
(2,709 Views)
