dfbg
Hi there. I have this VI that has an event structure in it, I was changing some aspects of the vi, broke the wire to the stop event, and "poof" the VI is broken and I do not have the ability to fix this with my BASE package of labview.
Can someone fix this issue with the event structure for me? It is broken in  "FC80-Serial-Event-80KW Blower.vi"
The VI "FC80-Serial-Event-19.vi" is an example of the event structure when It is working properly.
I have attached both.
Thank you for your time and efforts.
(2,977 Views)
Hi Vr6Fidelity,
right click on the event structure and select "chage this event" you can select the stop button with value change and it should work. I do it for you, see the attachment, but attention a delete one vi because it was absent.
Hope it helps.
Mike
(2,964 Views)
(2,961 Views)
