Add and delete user in table
Accepted by KinniHan
Hi KinniHan,
The constant value is still wired wrongly to the Index Array function.
The constant value is supposed to be wired to the disabled index (col), instead of index (row) terminal of the Index Array. It will extract out the 1st  column to later determine the number of data on that column.
Ee Lim
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
Message 11 of 13
(893 Views)
Oh my god, I didn't notice the error is because of this small mistake.Thank you so much and I will try more on array to adapt to this new environment 🙂
Message 12 of 13
(880 Views)
Hi KinniHan,
Glad that it works.
Happy learning. Smiley Wink
Ee Lim
Message 13 of 13
(871 Views)
