Add axis label to a graph in word report
    Is there a way to add an axis label for the graph in a word report? Thanks!
   Tom
(4,716 Views)
I would guess that there is, but it would be a word automation function.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,694 Views)
Hi Tom,
This white paper describes the capabilities of Windows Automation. You should be able to perform this task.
Creating and Customizing Graphs in Microsoft Word Documents from LabVIEW
You can also find some examples in LabVIEW that show how to create and modify graphs in Word using LabVIEW.
Warm Regards,
Josh
(4,653 Views)
Accepted by tom_z
It sure isn't very intuitive to use Word Set Graph Font vi to set the scale label.
Use xlCategory and the title input to set the x scale label and use xlValue and the title input to set the y scale label.
It would have been nice and easy to add an input to set the text orientation (just by adding an argument to the axis title property node).
Ben64
(4,640 Views)
Thanks all for reply!
I am sure automation function will work but I tried to use Word Set Graph Font vi as Ben suggested. It adds the axis label for both x and y axis. The only problem is that I can't rotate the y axis label.
(4,616 Views)
