Add date and time stamp to continuously streaming data
Hi all,
I am new to the LabView Environment and I am trying to setup a program to perform the following:
1. Prompt users to select an experiment
2. Display prompt messages to guide the users through an experiment
3. Collect Data from NI-DAQ in continuous mode.
I have completed task 1 and 2 but for task 3, I want to add time stamp adjacent to each data acquired. But I have not been able to do so. Please suggests what changes can I make to the attached VI to achieve my goals.
PS: Any suggestions on making the VI better would be highly appreciated.
(2,377 Views)
Accepted by topic author parajulis
I would try using the waveform instance of DAQmx Read to get time from the data acquisition system (and to time your loop). A little rearranging of the string manipulations, and here is an implementation that may work for you:
which produces a file like:
DP1 DP2 DP3 P1 8:02:26 PM 4/23/2021
0.0250 0.0250 0.0250 0.0250 8:02:37 PM 4/23/2021
0.0250 0.0250 0.0250 0.0250 8:02:38 PM 4/23/2021
0.0250 0.0250 0.0250 0.0250 8:02:39 PM 4/23/2021
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(2,345 Views)
Thank you Doug,
That worked very well.
(2,293 Views)
