Add elelment by element in an array of cluster
Hi All,
I have a problem in extracting data from array of cluster to a single cluster. Please have a look at the attachment.I have found the solution but it consumes lot of memory because of shif registers andi am using this many places which is loading to nearly 100% in RT. Please provide an better alternative solution.
Message 1 of 20
(4,372 Views)
Try Index Array. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 20
(4,363 Views)
I cant use index array because i cant predetermine how many active array elements in cluster. After indexing them i have to unbundle each cluster and build it again!!!!!!Very complex. I need a generic solutionSmiley Sad
Message 3 of 20
(4,359 Views)
Hi Geeta,
"i am using this many places"
When you do this operation very often, then why don't you store the data in the correct format?
The conversion from cluster of arrays to array of clusters is much easier (using BuildClusterArray)!
@Yamaeda:
How should an IndexArray help here? Geeta wants to convert an array of clusters to a cluster of arrays containing all values...
Message 4 of 20
(4,358 Views)
No i am almost at the end of coding . If i change the entire architecture affects. Only problem is this logic consumes more time. Pls any other idea...
Message 5 of 20
(4,353 Views)
What's wrong with plain auto indexing?
18431i70D3188621820610
That should give exactly the output you need.
Ton
My LabVIEW Ideas
Message 6 of 20
(4,347 Views)
Hi Ton,
Geeta uses a cluster of arrays. Indeed autoindexing would work, but then you need an additional ReshapeArray afterwards...
Message 7 of 20
(4,337 Views)
@Ton: This logic would give me the same output as input. No Change!!!
Message 8 of 20
(4,333 Views)
Hi Geeta,
you can use Tons suggestion as a starting point. It forms your array of clusters into a cluster of array as you wanted.
You only have to add a ReshapeArray for each array to reshape from 2D to 1D after autoindexing!
Message 9 of 20
(4,315 Views)
Standard situation if a propper data management is not done before coding OR  lead to the wrong architekture.
Do you use type definitions? Help a lot to avoid the horror of optimizing the datastructure.
Since it is much faster to rebuild a cluster by indexing the elements from your cluster of arrays than generating a cluster  of arrays from an array of cluster (Puh!)
AND you have timing problems I see only two solutions : Faster hardware or a reorganisation of your data.
So change the datasturcture , create a subvi 'IndexMyData2Cluster' and whereever you indexed the array of cluster  replace it with that vi.
Or run both structures in parrallel (BRRR, race conditions, inconsistent data , uuuaaahhh)
Greetings from Germany
Henrik
LV since v3.1
Message 10 of 20
(4,285 Views)
