Keithley 6514
Hello. I am writing a simple program that gets current readings from Keithley 6514 electrometer. I am trying to read from the buffer. Problem is that I get errors 230, 420, and sometimes 800. Not sure what is causing this, but i tried to de-bug step by step and noticed that as soon as i add the "Buffer Read" block errors 230 and 420 arise. I have attached my program. Is there something that i am missing here? Any help will be appreciated! Thanks
(4,379 Views)
We had similar problems using this instrument over a GPIB bus. We ended up changing the setting on the instrument and used serial comm instead of GPIB. We also built our own driver for our needs (setting up instrument and reading voltage); we stuck to strictly SCPI commands via VISA.
Why do geeks think Halloween and Christmas occur on the same day?
Because 31oct = 25dec!
(4,365 Views)
Is there an example that I could look at? Thank you so much for your time!
(4,362 Views)
