Add or delete from array base on a condition
Hi
I would like to add an element to an array if a condition is true.
For example in the attached picture, I would like to add one entry to array when the first element is yes, but I would like to add nothing if the first element is not yes
could you please let me know what should I add to false structure to not add any entry to array. I see if I use defualt value or defualt constant it still adds 0,0 to array
(3,665 Views)
do you have LV2013?
If so, you can use the new conditional tunnel output:
https://www.ni.com/docs/en-US/bundle/labview/page/conditionally-writing-values-to-loop-output-tunnel...
http://www.medicollector.com
(3,650 Views)
@josborne wrote:
do you have LV2013?
This is present in 2012 also.
Bill
CLD
(Mid-Level minion.)
(3,642 Views)
The conditional indexing came out with LabVIEW 2012.  That is the easy way.  If you are using older, then you need to use a shift register to hold your growing array with a Build Array inside of a case structure.
(3,638 Views)
I was too slow...
Jim
(3,633 Views)
Move that equals outside the loop (the optimizer probably does it anyway but, we should point out equals works with arrays)
(3,618 Views)
