Add two very big numbers
Hi guys
I am trying to add two big integers (like in Fibonacci sequence). Big, means much larger than I64. I wrote a vi, attached here, and I am wondering if it can be done better, aka faster (@Altenbach: if you provide a solution please add a ELI5 🙂 )
To explain, I am putting the numbers in arrays of U8 and do the addition as in elementary school.
If you have ideas how to do it faster pls let me know.
Regards
Message 1 of 24
(3,271 Views)
I once found this on the web.
Message 2 of 24
(3,251 Views)
@nitad54449 wrote:
Hi guys
There are several overcomplications in your code. Maybe you can have a look at my primitive factorial. The subVIs could easily be expanded to add two numbers.
One possibility to improve speed would be to use integers with more bits, each containing several digits. (e.g. base 10000000 instead of base 10)
Message 3 of 24
(3,231 Views)
Accepted by topic author nitad54449
A quick analysis of your VI:
  • The algorithm is flawed and gives incorrect results if the array sizes differ by more than one element. (e.g. try 1234+56. Your result is short!
  • Insert into array is the incorrect function to append to an array. either use "built array" of "reshape array". reshape has the advantage that it automatically pads with zeroes.
  • I don't think you need any case structure or green datatypes.
Here's what I might do. No guaranteed that it's faster... 😄
Message 4 of 24
(3,223 Views)
Hi Christian
I forgot to mention that the first number (array) is the same length as the second or, at most, one digit larger. I will take a look at your code and check it is faster,
thanks
Message 5 of 24
(3,217 Views)
Hi CA
after some tests, your vi is 3 times faster than mine !
thanks
Message 6 of 24
(3,207 Views)
I am sure it could be made a few orders of magnitude faster 😄
Message 7 of 24
(3,204 Views)
thanks
i tried the add and it does not work properly
N
Message 8 of 24
(3,199 Views)
be my guest 🙂
I am trying to find (just for fun) big Fibonacci numbers.
The 10^6 number has 200K digits, it takes 400 seconds with my code.
N
Message 9 of 24
(3,196 Views)
Here's a quick draft to generate the elements if the Fibonacci sequence. A google search for element 1000 shows the the result is correct.
As mentioned, it could still be sped up by orders of magnitude... 😄
Message 10 of 24
(3,178 Views)
