Labview PCI-6024E interface with DIGIPLAN CD20 drive
I have a DIGIPLAN CD-20 stepper motor drive system. Im using it to control two stepper motors. The problem is that the drive system has 10833a gpib bus connector and i have a PCI-6024e DAQ card.
How can i connect this motor drive to my daq card and program it using labview?
Can i directly connect this motor drive to my pc (without going through DAQ card) and program it directly using labview? (using VISA, Serial etc).  I have searched and found some GPIB to usb connectors. if i tried, can i use those connectors? or would i need a controller for interface?
any other ideas about how to program this drive using labview?
the user guide of my drive
https://www.parkermotion.com/manuals/cd/CD20-30.pdf
some other links
https://www.artisantg.com/PLC/74546-5/Parker-Digiplan-CD20-QUAD-Stepper-Drive-Module
https://www.radwell.co.uk/Buy/PARKER/DIGIPLAN/CD20/?redirect=true
GPIB TO USB connector that i mentioned
https://www.amazon.com/Kanonaki-GPIB-USB-HS-Interface-Adapter-Controller/dp/B07Q84XJJF
(1,232 Views)
Hi there,
P.12 of the manual mentions that the CD-20 drive will need "step pulses" to control it.  Usually you need a indexer or motion controller to generate these pulses.  My company has a solution for this, you can see here for more info: https://geco-lv.com/emotion.html
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source NI hardware? Try NI Trading Post
(1,191 Views)
