Add up hex bytes to form a word
What is the easiest way to add up hex digits in a string to form a word.
I am currently using the string to byte array and then the array elements, but this returns a byte only, i.e.xAA + xAA = x54
how do I return the full word which would be x0154 in this case?
(4,294 Views)
This addition can be done the way normal addition does. One thing you need to set is display type.
For this right click on control select radix from visible item and change it to hex.
CLAD
Passionate for LabVIEW
(4,281 Views)
I do not understand your question. Do you want to split your string into groups of two characters, convert each pair of characters to a number, and then add the numbers? Are all the strings the same length? What if there is an odd number of characters?
Please show a more general example than AA and AA.
Lynn
(4,275 Views)
here is an example of what I mean, the result is x54 when it should be x154
(4,268 Views)
Accepted by hydzik
You can't have a hex value of 154 in a U8 byte because you don't have enough bits.
Take your U8 array, and use the To U16 conversion bullet found on the Numeric >> Conversion palette.  That will give you enough bits so that you can add two U8's and not roll over.
(4,243 Views)
