Paulo,
I dont understand what you mean about putting the write to spreadsheet in. Do you mean putting it in twice would solve this or not? I'm looking for a top header to be as follows:
Time/Date | Channel 1 name | Channel 2 name | etc....
Could you possibly show me what you mean with the previous example I sent you.
Piero
You have your file wrong formatted, because, the first time you write to it, you write as a normal text file, and that will be how excel will interpret it. You have to replace the "Write characters to file.vi" by the "Write to Spreadsheet file string" that I sent you.
If you allow me, I would like to make some extra comments on your code:
1 - When you connect an array to a for loop, there is a property of the tunnel (the point where the array goes in the loop) that is auto-indexing. Right click it and select it. This replace all those index array that you have inside your for loops and the array size wired to the N input of the loop. This will automatically index the array and the loop will automatically run n times where n is the number of elements of the array.
2 - I'm not sure about this, because I didn't run your program, because I don't have a DAQ board installed in this PC, but I think that the secont For loops that you have (the little one) is doing nothing there.
3- try to keep your code more clean, you have it spread for a very big area with a lot of empty spaces and apparentl~y there is no flow from left to right in your code that makes it more difficult to understant it.
Hope this helps,
Paulo
