Adding 2 arrays to a Spreadsheet file Help!!
Sorry, but I'm not following you very well anymore.
Look at the annexed example, that's how I would do what you described on your side note.
Paulo
Message 11 of 19
(1,052 Views)
Paulo,
Very helpful example. If I wanted to start logging data only when a particular channel is high then how would I do that?
Message 12 of 19
(1,047 Views)
Check annex.
Choose the channel to use as trigger for the logging and the value to define high.
Hope this helps,
Paulo
Message 13 of 19
(1,043 Views)
Sorry, forgot the attachment.
Message 14 of 19
(1,041 Views)
I dont know what you mean by the example its the same one you sent before. I need to have a channel that triggers on a voltage level. What is Annex?
Message 15 of 19
(1,041 Views)
Sorry, wrong file...
Annex is the attachment.
Message 16 of 19
(1,039 Views)
Paulo,
If you run the program once and then rerun it again the program gets into a loop and it keeps asking you to choose a file name.
Some other questions if I may ask. With my previous program that I wrote it seems as though mine is quite lengthy but yours does the same thing. I believe that yours can run faster because it has less loops?
Will the program that I attached work for the tigger function.
Thanks again.
Message 17 of 19
(1,028 Views)
I guess you can use yours too. The only thing you have to change is that you wire the same condition I built to your case structure instead of that save file button you have now.
Cheers
Paulo
Message 18 of 19
(1,025 Views)
Paulo,
If I were to use your example 1.vi, how would I be able to have it so that when its 12am it closes the write to spreadsheet file and starts a new one.
Message 19 of 19
(986 Views)
