Adding Data to Exisiting Data File
I am trying to find out if there is any way to write data onto an existing data file as a new line. I currently write one line of data at a time, reposition my test set-up and then re-run the same test. Instead of writing a new file each time I run my test and copy and pasting them together later on, I was wondering if there is a way to open an existing file, read the data that exists and then add a new line of data while keeping the old data. If anyone has advice or has a quick solution, please let me know. Thanks
(3,874 Views)
The way that I am writing to a file is "Write to Spreadsheet file". I am using LabVIEW 8.0 if there are any questions with the version.
(3,872 Views)
With Write to Spreadsheet file, do you see the input called 'append to file? (new file:F)'? Just wire a true constant to it. If you are not already doing it, go to the help menu and select 'Show context Help'. This will pop-up a help window for each function as you move your mouse over. You'd be surprised at the amount of information the built-in help system has.Smiley Wink
(3,866 Views)
Dennis,
I'll check that out, thanks
(3,860 Views)
or you can use the long way round which works with most filetypes.  You may or may not need the carriage return.
Craig
Message Edited by craigc on 02-29-2008 10:52 AM
LabVIEW 2012
(3,851 Views)
