telnet
  I have a question on how to pass measured values from labview to a seperate database using telnet.
I have tried on establishing the connection with the database using telnet using telnet line client.vi, and im able to do that successfully. Can anyone suggest me on this with some example Vi's if possible.
Thanks in advance,
Navin
(3,451 Views)
Hi Navin,
I've found a couple of different resources that might be helpful for using Telnet. The first is a Knowledge Base called How Can I Use the Telnet Communications Protocol With National Instruments Software?. This Discussion Forum thread has 2 simple Telnet vis. There are also two different Developer Zone articles that have Telnet vis. They are located here and here. I hope this helps get you on your way.
Hillary E
(3,431 Views)
