Sony XCD-SX910 IEEE 1394 drivers
I am a new labview user. I have got labview 8.5. and I want to control Sony XCD-SX910 IEEE 1394 to make it grap image and storage it. Are there any dirvers for Sony XCD-SX910 IEEE 1394. I really do need it. Thanks for your help ! Gilbert Tan
(4,833 Views)
For your camera to work with LabVIEW, firstly you will need to have NI-IMAQ for 1394 or IMAQdx, our drivers for firewire cameras. The camera must also be DCAM compliant. However, since you have a consumer camera, this is unlikely to be the case.
The following links have some more information that should allow you to check whether it is compliant or not:
http://digital.ni.com/public.nsf/allkb/ABB267CAE2DCA5B386256F820074A7ED?OpenDocument
http://digital.ni.com/public.nsf/websearch/AFDED7F599E8A73A8625689E007672E5?OpenDocument
Dan - NIUK
(4,808 Views)
Dear Dan,
Thanks for your answer.
I have NI-IMAQ for 1394 and IMAQdx, and I dont know which dirver I should choose.
It means I don't know which one is better for Sony XCD-SX910 IEEE 1394.
Thank for your help
Gilbert
(4,795 Views)
Hi again,
I would recommend using the IMAQdx drivers, since these are newer than the IMAQ for 1394 drivers, and are designed for newer generations of cameras.
Dan
(4,789 Views)
