Adding a 2nd, 3rd etc. input to Formula
In the examples section there's
"Lissajous with Express VIs.vi"
in the Examples section under
/Fundamentals/Graphs and Charts/
I can remove both inputs from Formula and re-add them, but I cannot add a 3rd input in addition to 'Trim' and 'X'.
Also, I wonder how to change the text from 'Simulate Signal' to 'Simulate Signal for Horizon/Vertical' as done in the example.
(5,679 Views)
Accepted by Starhowl
You simply need to define a formula that contains more parameters.
You cannot have three inputs to a formula that uses only only two variables.That would make no sense.
Have you tried double-clicking the formula express VI? Have you looked at the help?
(5,667 Views)
Adding the alias to the formula worked; do you also know how to change the text on the 'Simulate Signal' part?
(5,662 Views)
Just double-click the text and change it. 😄
(It is the "caption" of the express VI and you can also hide it by right-click...visible items...))
(I would recommend you don't focus too much on express VIs, but learn "real" LabVIEW instead. Express VIs tend to hide a lot of code and dynamic wires obscure their content to the casual observer).)
(5,652 Views)
