Adding time stamp with every element of a 1D array
Hi
   I want to add a real time stamp with every element of a 1d array before writing to a spread sheet.
kindly guide me how to do this.
Best Regards,
RASHID
(6,463 Views)
Accepted by Rashid931
Hi Rashid,
Where is this Array coming from? Is it measurement data from a NI DAQ Device?
If so you could simply change the datatype to Waveform, where a timestamp is included.
On the other hand you could also create a waveform out of your 1D array using build wavefrom, like here:
21015i15C15D6FE4F1905C
Christian
(6,453 Views)
@Christian_M wrote:
Hi Rashid,
Christian
And you can use Export Waveforms to Spreadsheet File.vi to easily write the data to file.
Richard
(6,439 Views)
You previously asked about doing a adding a timestamp for a 2D array, and about doing array comparison with a threshold. How many different threads are you going to start on the same question? Keep the discussion in ONE place so everone knows what's being asked, the objective, and the suggestions already proposed.
(6,421 Views)
