Advanced Edited display format (Numeric)
I a question wich look be easy
I have an indicator (Numeric I32)
This indicator has 9 Digit
I want to have specific display
9 Digit = DDDDDDDDD but I want DDD 'space' DDD 'space' DDD
does anyone can help me ?
It should be good to have a method for indicator and command.
Message 1 of 9
(5,957 Views)
I don't think you can do it directly.  For an indicator, you could use a string indicator and use string functions to break apart the digits and add spaces.
There is an idea on the Idea Exchange to add such a feature.  Go to Visual Aides - Numeric Separators and vote for it.
Message 2 of 9
(5,949 Views)
I don't think you can. I don't see anyway to do it in LabVIEW 2013.
I am thinking you are going to have to write your own string indicator.
Message 3 of 9
(5,945 Views)
As I want to have the same display for command, I prefer not use text display.
If it is not possible, maybe this display can be post to NI Ideas
Message 4 of 9
(5,942 Views)
Accepted by Minikisscool
Message 5 of 9
(5,929 Views)
wouah, in 2009, it is very old.
what are doing NI ?
Message 6 of 9
(5,921 Views)
what are doing NI ?
For as small of a team as they have to work on LabVIEW, A LOT.  Stability has been the main focus as of late.  But there are a TON of feature requests.  They can only handle so many at a time.
Message 7 of 9
(5,905 Views)
Don't forget to vote for the idea.  Every vote will boost the popularity and be more likely they will give some priority.
Message 8 of 9
(5,892 Views)
Thanks, I did
Message 9 of 9
(5,885 Views)
