Afficher cluster
Bonjour,
J'aimerais programmer l'algorithme suivant sur labview:
For i=1 to N
      Afficher cluster 1 to N;
End for;
Merci de m'aidez svp!
Je vous joint le debut de mon programme!
Cordialement
(3,880 Views)
Bonjour,
Je n'écrise pas francais.
Is this what your wanted?
André
André (CLA, CLED)
(3,868 Views)
@karlito20 wrote:
For i=1 to N
End for;
You have an cluster of clusters, and not an array of clusters, thus you cannnot programmatically change the number of elements. What is the purpose of the "visible" property in your example code?
If you think André has the right answer, here's a sinpler way to do the same thing.
(3,862 Views)
I have a cluster and in this cluster, I have clusters(cluster 1, cluster 2, cluster 3,...,clusterN,...,cluster 30).
With a numeric control, I have to select cluster
For example, if numerical control is 3, cluster 1,2 and 3 are selected.The other cluster are disabled and don't visible.
I would like to see appearing scrollbar.
Is it possible???
Thanks a lot for your Help.
Regards
(3,859 Views)
@karlito20 wrote:
Is it possible???
Everything is possible (see attached. You might want to disable FP updates during the loop, though).
Still, I feel this entire thing should be designed differently. What are you actually trying to do?
(3,853 Views)
Can you post me the vi in Labview 7.1, please?
Thanks a lots!
(3,851 Views)
No, but here's an image:
Message Edited by altenbach on 08-27-2007 10:02 AM
(3,847 Views)
