08-27-2007 09:15 AM
08-27-2007 10:00 AM
08-27-2007 12:02 PM
Code which uses the call library nodes call external dlls. when building these applications you must include the referenced dlls just as you have to do with any dynamically called code. this can be difficult for some instances if the vis are locked it might be hard to determine which dll you need.
paul
