After an install executable is missing Sub VI's
Dear altenbach,
there is no such folder and I am not sure if I am supposed to see such directory, but if you ask for specifically that folder, then I guess I should..
Even the generated preview is lacking the 'data' folder - see attached screencaptures.
(on the left my source file settings, on the right the generated preview)
What am I missing?
Message 11 of 22
(2,084 Views)
Just guessing but did you ever install the min runtime by mistake (instead of the full version)?
(the missing data folder is probably OK, it simply means that you don't use any advanced analysis, etc.)
Message 12 of 22
(2,071 Views)
I am actually running this VI on the laptop where I have the Full Development Environment (and where I created the exe).
I am not running anything parallel, I have no other programs open, LV also closed.
Message 13 of 22
(2,065 Views)
You already said virtually all of that. Are you replying to any particular post?
Message 14 of 22
(2,061 Views)
I was replying to the suggestion that I installed the min run-time on the Pc where i am trying to run the exe, which is not the case. When running the exe on the source laptop such issues should not come up I assume.
Message 15 of 22
(2,048 Views)
OK, this is now a much clearer answer. 😄
Message 16 of 22
(2,045 Views)
Can you attach the executable?
Message 17 of 22
(2,030 Views)
Sure, but only tomorrow morning.. Sorry I left already.
I'll do it first in the morning, thanks in advance!
Message 18 of 22
(2,019 Views)
I am sending my application files attached (zipped).
Message 19 of 22
(1,984 Views)
Sorry, I have no idea what could be wrong. Hopefully somebody from NI will take over....
Message 20 of 22
(1,928 Views)
