Agilent 34401A - Reaching 1000 samples per second
I've been trying to find a post with the correct answer, but the closest has been this one:
https://forums.ni.com/t5/LabVIEW/Increasing-reading-rate-of-34401a/td-p/1230535
In summary, have anyone reach 1000 samples per second using the Agilent 34401A with GPIB and LabVIEW. I have followed all the guideline to achieve maximum sampling rate, but i can only get data as fast as ~120 samples per second.
Thanks!
P.D. I know if I change the hardware I can achieve that sampling rate easily.
(3,745 Views)
Hi Javy, please post your code.
(3,734 Views)
Hi Gregory,
Due to my work environment, I'm won't be able to upload this code. Let me create a generic example, and I will upload it soon. However, my interest is just to know if anyone have reached this sampling rate using LabVIEW.
(3,708 Views)
Hi Javy,
did you follow this advice?
(3,645 Views)
Hi GerdW,
Yes, I followed that setup, and the one the is in the Keysight DMM manual. In fact, I also verify the Agilent manual to verify the SCPI commands are the same (maybe unnecessary extra work :S ).
(3,591 Views)
