Agilent 34465A Help
Remember also that these meters only have a limited buffer size.  You will need to determine how you wish to handle that without overflowing the buffer.
You may need to flush/clear the buffer each time you take an average and possibly holding onto that average for several iterations.  Thereby taking an average of averages in order to create a rolling average.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 13
(1,764 Views)
Thanks for the tip.  I hadn't read up on buffer.  I just assumed it was like the Hp3478a buffer that overwrote everything on every trigger event.  Worth looking into!
Message 12 of 13
(1,759 Views)
Accepted by topic author costleyboy
Thanks guys for the help, this is the solution I eventually settled on.
Using the level triggering main.vi
Message 13 of 13
(1,715 Views)
