how to (re)play captured (import) data in NXG
Hey,
I have imported a csv file into NXG -> visible in 'captured data'.
But I'm not finding an easy way to play the waveform.
In documentation, it's suggested that one has to use an analysis panel. But I'm also not able to find such an analysis panel, except offcourse the chart, graph, etc. objects...
Can anyone help or give me a hint?
thx
(2,500 Views)
Accepted by topic author kdCMC
I think I found it by following the incorporated lessons in the NXG environment: my problem is that I imported from csv file with resulting in string values, not compatibel to view in analysis panel and so display's only the array with the values. When using e.g. DBL type (captured from e.g. a simulation), by double clicking the captured data key, the analysis panel appears with the resulting graph or chart.
(2,469 Views)
