LabVIEW crash and .dmp file
Hi, I have a TestHarness.exe file which calls a LabVIEW FPGA dll and this has worked fine for some time, however, I had a TestHarness crash which I have never seen before
This points to a LabVIEW Data folder which contained a lvlog.txt file and a .dmp file.
How can I view the .dmp file?
(5,723 Views)
Dump files are for NI, see:
https://forums.ni.com/t5/LabVIEW/Dump-file-analysis-help-please/td-p/3614819
https://www.ni.com/en/support/documentation/supplemental/18/ni-error-reporting--nier--faq.html
Otherwise, I would check with the program's developer.  They may have more insight on the issue you are experiencing.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(5,694 Views)
