Agilent 81110A single pulse
I'm programming an Agilent 81110A pulse generator for singles pulses, using LabVIEW 8.5. I downloaded a collection of VI for this device in NI page. I could set in remote mode a "triggered manual key mode " using the "trigger pulses VI" , but I can't simulate de "man" button like the one on the panel for executing the single pulse.
Thanks!
(3,046 Views)
Thanks!
(3,045 Views)
Hi Cutu,
what about reading the manual of your device?
I guess it contains a chapter on programming: just find the command needed to "simulate" that button…
(3,011 Views)
Hi. I also set up a single pulse system nowadays with Labview
I found all the command what I need from 81110a manual, but I am also struggling in executing MAN button by LabVIEW.
If you solve this problem, Could you help me to solve this problem?
(2,776 Views)
