Change Windows Latency time
i need to change latency time in registry.
I found this on community, and follow example.
https://forums.ni.com/t5/LabVIEW/Can-I-change-default-settings-for-Windows-Serial-Latency-times/td-p...
But unfortunately, error occured every time.
Please check in att.
Can someone give solution?
Milan
(2,414 Views)
Hi milan,
"access denied" means "access denied"!
It's the OS (aka Windows) which limits access to registry keys. Avoid to fumble with registry - or get sufficient rights to be allowed to change keys…
(2,394 Views)
