Agilent digitizer U1082A query ID failed -1074003967
Dear members,
I have -1074003967 error when initializing my Agilent U1082A digitizer.
Discription: I have 64-bit OS, Windows 7, LabVIEW2009, Agilent U1082A digitizer is installed on PCI slot6 and is visible under Windows device manager.
Problem: I try to run a demo LabVIEW program, but it shows error saying "parameter 1" is out of range, where parameter 1 is instrument ID (AcqirisDemoError.png)
What I did:
1. tried AcqirisLive software provided by the manufacture and was able to see the card & calibrate it.
2. checked drivers (AgilentDriversInstalled.png), they are installed.
3. checked VISA (VISA.png)
4. checked NIMAX (NIMAXdirectory.png), I can see card in PCI6, but I'm a bit concerned because PXI system is "unidentified", can this cause the problem? How to fix it?
(2,779 Views)
Hi rosinefish,
do you use a PXI system at all?
Where did you install that Agilent device? In your Windows computer or in an external (PXI) system?
You don't need VISA for your device.
MAX should not care about the Agilent device as it is no NI DAQ device…
Did you call the Agilent support?
(2,735 Views)
Accepted by rosinefish
That's not really an example program, so much as a subvi (subroutine) or part of a program.  Running this without first setting up communications is most likely going to give you an error.  (Like trying to talk on your phone before you dial the number - useless!)
The LabVIEW driver should have an Examples folder, wherein you will find full applications for common tasks.  These examples will still be pretty primitive, but they at least demonstrate all the steps required to make a measurement.  Usually its something like;
initialize communications
configure or query measurement settings
configure and arm trigger
trigger
wait for measurement complete
read data
If not, then look at the "VI Tree.vi" for a sense of the way you need to string the subvis together to accomplish your task.  Post attempts here and we can help debug if you get stuck.
Craig
(2,732 Views)
Thank you very much, problem solved. I need to initialize the digitizer before calling it for data acquisition. There is a subvi from driver files that can do this. "Initialize.vi" is the name.
(2,724 Views)
Thank you for your advice! Turned out I need to run initialize.vi first. Problem solved.
(2,723 Views)
