Ajuda para Conectar um Indicador Digital Antigo a uma Máquina de Tração com LabVIEW
Hi GerdW,
Is this helpfull  ?
Message 11 of 14
(376 Views)
Accepted by MarcusP.
Hi Marcus,
this PDF manual looks promising!
Read chapter 21 and implement the protocol description in LabVIEW…
Message 12 of 14
(371 Views)
Hello GerdW,
I would like to express my deep gratitude to everyone who helped me with my LabVIEW questions. Thanks to the support and valuable suggestions I received here on the forum, I was able to overcome the challenges I was facing and successfully complete my project.
Your generosity in sharing knowledge and experiences was essential to my progress, especially during the times when I was stuck with technical issues. Every tip and piece of guidance was extremely helpful, and I cannot thank you enough.
I hope to give back in some way in the future by helping other members in the same way I was helped.
In the end, I had to find the manual for this product (which I found through an image of the non-functional manual that I had previously sent), and now I'll try to help anyone with a similar problem.
During the serial reading, I received the following functional return:
2024-08-13 14:14:51,474752 +0,000005 9F050024:- 0.011 20050024:
At this point, I had to look at the manual to figure out what the commands were. I filtered this serial return, which initially was 20050024:\r\n, but when I managed to analyze it, I realized that something was still missing. After checking the other returns, I saw the 9F050005 part, which was the missing element and appeared in the return.
By combining everything, I ended up with 20050024:9F050005\r\n, finally getting a return that visibly helps:
9F050024: 0.146 G
This is the effective distance (I still don't know how to filter it for use in the graph, but that wasn't the main issue).
Thank you all very much!
Message 13 of 14
(327 Views)
Q bom que conseguiu encontrar o protocolo de comunicacao !
Message 14 of 14
(316 Views)
