Alignment problem in a graph when build
I would really appreciate your help.
I am turning around trying to align a legend of a graph.
My application is coded in Labview 2014 in Windows 7. Before it was in XP and older LabVIEW and I had no problem.
I have a user interface with a graph. I made my interface look good. When I build the interface is not the same in the exe version. I have attach a copy of what the interface should look like. I also a copy of the interface in EXE. In the exe image, I have circle the part which is not align. Is their a way to correcte that?
Thanks in advance!
(3,368 Views)
Hi cynt,
most often you will need to set FONT properties in the executables INI file. Usually keys like
FPFont="Tahoma" 13
BDFont="Tahoma" 13
appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
do the trick…
(Replace "Tahoma" and 13 with your favorite settings!)
(3,365 Views)
Not sure if we're having the same problem, but this is what happened to me yesterday:
I created a chart from the System Suite, added some channels to the legend by resizing in horizontal direction, named some of them and then made the legend smaller again. After I did this the entire Legend was shifted to the right a couple of cm.
Remember Cunningham's Law
(3,361 Views)
Accepted by cynt
I have solved my problem with creating a typedef control with my graphic. When I first open the controle to customise it, I notice that if I try to change something on the graph the legende keep become smaller.  Probably, the size it is in the EXE. So I tried to ajuste de size so that the size do not resize by itself in the customize window. Then with the size adjust, I create the EXE and the size did not change.
Hope this can help someone else!
Thanks for your help
Cynthia
(3,302 Views)
