Alt-Click to move connected items on block diagram
Often, in block diagrams, I'd like to be able to slide all connected items together so they stay in the same relative position to each other.  Currently, to move multiple items, you have to select them (rubberband), then click and hold to move them.  It would be convenient if you could just hold Alt, then click, and have Labview automatically select all the items connected to the point you clicked.
(2,730 Views)
Ok, I posted this message to the wrong group (I meant to put it under Ideas).  How do I delete it from this group?
(2,723 Views)
Accepted by ishmael
You can't. If you really want to delete a thread you need to send a note to the moderator. Simply select "Report to Moderator" from the Options menu (above and to the right of the message). I'm assuming you intended this to go into the LabVIEW Idea Exchange.
(2,713 Views)
