Alternate between digital output and analog input
Accepted by JPROC
This is a case where if one way of thinking about your problem isn't helpful, come up with a new way.
Don't think about switching between devices. Think about one 8-bit dataspace that just happens to be split between two devices.
The basic flow from my last upload will still work, but because there are two devices involved, there are two tasks that need to be created, updated and cleared.
Try this...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(578 Views)
Try this...
Mike...
Thanks!  It wasn't that I hadn't thought about the problem in that way, it was that I had no idea how to program it.
Earlier you had brought up the point about a race condition where the consumer loop wouldn't process the last item in the queue.  Again, because I'm so new to this I don't know what to do to prevent this from happening.
suggestions?
Message 12 of 13
(561 Views)
Never mind the other comment, brain fart - I was probing in the wrong place.
Mike...
PS: Feel free to drop some kudos when you see something you like...
LabVIEW Champion
Message 13 of 13
(552 Views)
