Alternate way of finding the Windows Reference Number
I am using some of the Windows Utilities VIs and I have run into a snag. In my application I lauch multiple template VIs and hence have many Windows that have the same name. This causes a bit of confusion when using a VI like "Flash Title Bar" which takes in a window's name to determine it's reference number. MY question is, is there an alternative method of finding out a window's reference number without having to supply the window's name? Something that determines each window's unique number. I checked various Application and VI Properties without much luck. Perhaps is there some way of converting VI reference to Windows Reference. I dunno. Any ideas???
Thanks fellow LabVIEWers,
Glen D.
(3,904 Views)
AstroMed Glen wrote:
> Hello,
Hmm, try attached VI. LabVIEW 7.0 and higher only!
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,904 Views)
Hello Rolf,
can you unlock the diagram of your vi?
Where do I find the type definition "window refnum (NaWR)"?
(3,904 Views)
Is that one included in the winutil.llb file? I didn't see it there. You must have made it yourself. Well thank you. I will give it a go in a bit. I have just been side-tracked to a different project for the rest of the afternoon. I will try it out before the end of the day and comment back to you. Thanks again.
(3,904 Views)
Sorry, I can't.
It's in the original winutil.llb or similar library.
Rolf Kalbermatter
(3,904 Views)
Here is an unlocked version of the Get Windows Refnum vi along with the Window Refnum control.
- tbob
Inventor of the WORM Global
(3,904 Views)
